I would like to couple a constant-current source with a high-side H-bridge and it seems to be way more difficult than expected.
In the end, it is a constant current source from 0-10 mA with a voltage of 100 V, where the current can be applied in both directions of the load.
I tried to simulate it with LTspice, but I always get high-current pulses when switching and the current has a larger offset through the leakage of the resistors of the PMOS.
To activate the current pulses, I use the shut-down channel of the op-amp together with the trigger pulses, otherwise it integrated into saturation when the high side is open-circuit.
The MOSFETs here are rated at only 100 V. I know these are the wrong ones and it is just used for the simulation and gives the same output also with a lower supply voltage.
Any ideas for another approach or improvements? I already tested with optocouplers (too slow) and directly with NMOS and a charge-pumped driver (works pretty well, but seems to be a more difficult approach).
Edit: My Goal is a bidirectional constant current source, adjustable in between -10mA and 10mA, providing up to 100V, so that it has a high load impedance range. I found several topologies that might do the job, like the howland current pump, but all of them I found need a split supply, which in the end needs +-100V. I think it should be possible to achieve this with only a single-ended 100V supply and a High Side Switch topology.
Edit2: Indeed the howland current pump seems like a good idea for a current source up to around 100mA and around 100V split supply, but what if one want lets say 500V at 10mA? OPAMP prices in this area explode and MOSFETs are very cheap, where also gate drivers with charge pump are really affordable in comparison with the OPAMPs. So, a high side switch topology seems still to be a good idea from my point of view. Any ideas what other possibilities there would be for very high voltage and low but constant current sources?
