This is my first 4-layer design and I can't easily find a clear answer to this question. I am designing a 4 layer PCB (signal-GND-pwr-signal), where regulated +12 and -12V power is supplied through a 3 pin connector (THT), along with the chassis GND connection.
In a two layer board, I would locate the board-wide bulk capacitors (220uF, aluminum electrolytic) adjacent to the main power connector, and route the power traces first from connector to capacitor, and fan out from there to the other Vcc pins of ICs, etc.
Since the main power connector is attached with through-holes, the board-wide copper pour for the power layer wants to attach to the incoming Vcc+, in addition to the positive pin of the bulk capacitor. (I also linked the capacitor and the connector directly by a fat trace on the top layer.)
Should I add a keep-out that prevents the connector from directly linking to the power plane? (Forcing the power plane to pull only through the THT pin for the bulk capacitor, which backhauls to the main power supply through the 2mm-wide top layer trace?) Or should I just allow both the power jack and the capacitor to connect to the power plane independently?
