I am trying to learn about transistor biasing, and can’t seem to wrap my head around it.
First of all I’ll explain what I’m trying to accomplish. I’m trying to build a linear 0-100 V power supply which will be capable of supplying loads with a varying impedance. I would like to be able to control the voltage to a motor or soldering iron which usually have quite a low impedance. I also intend to use this power supply for anodizing titanium, which has a relatively high impedance (~3-5 kΩ).
Ideally I would like to be able to control the power supply with a potentiometer, but I’ve blown up almost every single one I have now.
I’ve attached a photo of the circuit I currently have. Along with it you can see the spice analysis and transistor arrangement with a 0.7 Ω resistor as the load. The test is a DC sweep at V1 from 0-100 V with the potentiometer fully open.
While testing my circuit I found that the transistors aren’t fully saturated which would be why I’ve damaged so many. Also I do know that using a motor with this low an impedance would use a huge amount of current and requires multiple transistors in parallel to provide it.
Could someone please help me to understand how to correctly bias a transistor with a varying load impedance?
