I have a task of creating a boost DC-DC converter that can convert 3-4 V input into 12-16 V output with 100 W power and high efficiency.
There is nothing similar that I could find on the internet. Could someone give pointers to such designs or ICs?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have a task of creating a boost DC-DC converter that can convert 3-4 V input into 12-16 V output with 100 W power and high efficiency.
I have used one of my ready-made free templates with a 200-kHz interleaved boost converter operated in CM and I can deliver 100 W from a 3-V source. The inductor current peaks to 19 A and the rms current in the output capacitor is 8.3 A:
It's obviously not a design but rather a quick sim to show that, on the computer, you could deliver 100 W from the 3-V cell: there is obviously more to explore on the subject : )
An update: TI Workbench didn't help as it couldn't find anything suiting my parameters. Also I'm not proficient enough to use the information in the answer by Verbal Kint.
However I was able to partially solve this task by using SC8802 DC-DC converter chip, which also has a nice feature of working bi-directionally, i.e. in addition to boosting the battery voltage it also can charge the battery from an external DC source.
I used SC8802 along with 4 pcs of BSC015NE2LS5IATMA1 147A MOSFETS, as well as 7443642200 30A inductor. I was able to get 60W power out of a single Li-Ion cell. The current draw from the cell was almost 20A and the efficiency was about 86-89%.
I guess I can tune this circuit to achieve higher power. However it looks to me that it may be quite hard to achieve higher efficiency, if at all possible.
