I am trying to design a matrix multiplier using systolic arrays architecture. The inputs are 1D arrays with 2's complement 16bits elements. Here is my code:
 `timescale 1 ns/ 1 ps
module sys_array_tb;
reg reset, clk;
localparam  M = 2;
localparam  N = 2;
localparam  DW = 16;
reg start;
reg signed [DW-1:0] W [M*N-1:0];
reg signed [DW-1:0] X [M*N-1:0];
wire signed [DW*2:0] Y [M-1:0];
wire done;
systolic_array #(.M(M),.N(N), .DW(DW)) uut(.clk(clk), .reset(reset),
                                    .start(start), .X(X),.W(W),.done(done), .Y());
initial begin
    reset <= 1;
  clk <= 0;
  #3
  reset <= 0;
  #3
  W = {16'h0234, 16'h1345, 16'h2456, 16'h3567};
  X = {16'h0234, 16'h1345, 16'h2456, 16'h3567};
  start = 1;
  #3
  wait(done);
  #3
  W = {16'h1234, 16'h2345, 16'h3456, 16'h4567};
  X = {16'h1234, 16'h2345, 16'h3456, 16'h4567};
  wait(done);
  #3
  W = {16'h2234, 16'h3345, 16'h4456, 16'h5567};
  X = {16'h2234, 16'h3345, 16'h4456, 16'h5567};
   wait(done);
  #3
  W = {16'h3234, 16'h4345, 16'h5456, 16'h6567};
  X = {16'h3234, 16'h4345, 16'h5456, 16'h6567};
   wait(done);
end
initial begin
    repeat(100)
        #5 clk <= ~clk;
end
initial begin
    $dumpfile("wave.vcd");
    $dumpvars(0, sys_array_tb);
end
endmodule
module systolic_array #(
    parameter M = 2,
    parameter N = 2,
    parameter DW = 16
  input clk,
  input reset,
  input start, // start of the process
  output reg done,
  input signed [DW-1:0] W [M*N-1:0],
  input signed [DW-1:0] X [M*N-1:0],
  output signed [2*DW:0] Y [M-1:0]
reg calc_done;
reg signed [DW-1:0] A_reg [M-1:0][N-1:0];
reg signed [DW-1:0] B_reg [M-1:0][N-1:0];
reg signed [2*DW:0] C_reg [M-1:0][N-1:0];
integer m,n;
always @(posedge clk) begin
  // initializing
  if(reset) begin
    m = 0;
    n = 0 ;
    calc_done = 0;
    done = 0;
    //  count <= 0;
    for(m=0;m<=2;m=m+1) begin
      for(n=0;n<=2;n=n+1) begin
        A_reg[m][n] = 16'd0;
        B_reg[m][n] = 16'd0;
        C_reg[m][n] = 33'd0;
        end
      end
  end
  else begin
    if (start) begin
      // converting 1D array to 2D
      for(m=0;m<=M;m=m+1) begin
        for(n=0;n<=N;n=n+1) begin
          A_reg[m][n] = W[(m*M+n)*16+:16];
          B_reg[m][n] = X[(m*M+n)*16+:16];
        end
      end
      if(!calc_done) begin
        C_reg[m][n] = res[m][n];
        if(n == N) begin
          n = 0;
            if (m == M) begin
              m = 0;
              calc_done = 1;
            end
            else m = m + 1;
        end
        else n = n + 1;
      end else if(calc_done) begin
        // converting 2D array to 1D
        for(m=0;m<=2;m=m+1) begin   //run through the rows
          for(n=0;n<=2;n=n+1) begin    //run through the columns
            Y[(m*M+n)*16+:16] = C_reg[m][n];
          end
        end
        done = 1;
      end
    end
  end
end
wire [DW-1:0] a_ins [M-1:0][N:0];
wire [DW-1:0] b_ins [M:0][N-1:0];
wire [2*DW:0] c_outs [M-1:0][N-1:0];
wire [2*DW:0] res [M-1:0][N-1:0];
genvar  i,j;
generate
  for (i = 0; i < M; i = i+1) //: Rows
  begin
    for (j = 0; j < N; j = j+1) // : Columns
    begin
      PE #(.DW(DW)) pe (
        .clk(clk),
        .reset(reset),
        .x_i(a_ins[i][j]),
        .y_i(b_ins[i][j]),
        .x_o(a_ins[i][j+1]),
        .y_o(b_ins[i+1][j]),
        .mac(c_outs[i][j])
    end
  end
  for (i = 0; i < M; i = i +1) begin
     assign  a_ins[i][0] = A_reg[i][0];
  end
  for (j = 0; j < N; j = j +1) begin
     assign b_ins[0][j] = B_reg[0][j];
  end
        assign res[i][j] = c_outs[i][j];
     end
  end
endgenerate
endmodule
module PE #(
    parameter DW = 16
input clk,
input reset,
input signed[DW-1:0] x_i,
input signed[DW-1:0] y_i,
output signed[DW-1:0] x_o,
output signed[DW-1:0] y_o,
output signed[2*DW:0] mac // multiply and accumulate
reg signed[DW-1:0] x_reg,y_reg;
reg signed[2*DW:0] mac_reg;
  if (reset) begin
    x_reg <= 0;
    y_reg <= 0;
    mac_reg <= 0;
  end else begin
    x_reg <= x_i;
    y_reg <= y_i;
    mac_reg <= mac_reg + (x_reg * y_reg);
  end
end
assign x_o = x_reg;
assign y_o = y_reg;
assign mac = mac_reg;
endmodule
I'm getting the following errors when running the simulation:
ncelab: *E,TYCMPAT (./mult.sv,126|24): assignment operator type check failed (expecting datatype compatible with 'packed array' but found 'unpacked array [15:0] of signed packed array [15:0] of logic' instead).
ncelab: *W,BNDMEM (./mult.sv,126|24): Memory index out of declared bounds.
ncelab: *E,TYCMPAT (./mult.sv,127|24): assignment operator type check failed (expecting datatype compatible with 'packed array' but found 'unpacked array [15:0] of signed packed array [15:0] of logic' instead).
ncelab: *W,BNDMEM (./mult.sv,127|24): Memory index out of declared bounds.
ncelab: *W,BNDMEM (./mult.sv,146|12): Memory index out of declared bounds.
ncelab: *E,TYCMPAT (./mult.sv,146|40): assignment operator type check failed (expecting datatype compatible with 'unpacked array [15:0] of signed packed array [32:0] of logic' but found 'packed array' instead).
I might miss something obvious, but I'm not sure how get to these datatypes match. Any comments would be appreciated.
To understand the error message, in the following assignment:
set m=n=0:
      A_reg[0][0] = W[0 +: 16];
which is the same as:
      A_reg[0][0] = W[15:0];
That expression for W does not make sense.
With M=N=2, the input declaration resolves to:
input signed [15:0] W [3:0],
That is an array of 4 16-bit values. Let's assume you want the following 4 16-bit assignments:
  A_reg[0][0] = W[0];
  A_reg[0][1] = W[1];
  A_reg[1][0] = W[2];
  A_reg[1][1] = W[3];
Then, this would be the for loop:
      A_reg[m][n] = W[ (2*m) + n ];
This resolves the error message for that line of code.
