I have an ATTEN ADS1062CML 60 MHz 2-channel digital oscilloscope and it has quite poor input sensitivity. My idea is to build a 2-channel low-noise pre-amplifier. I mostly need the oscilloscope for debugging vacuum tube audio circuits.
I came across an article "Measure Milli-volts with Decade Amp" in Radio Electronics magazine 1960-09, which describes an add-on for a voltmeter or oscilloscope. It has a gain of 100, 5 Hz - 1MHz bandwidth, 1 MΩ input resistance, 1 kΩ output impedance, and because of the vacuum tubes used (3 x 6AK5), it is immune against input overload. Noise with input shorted is 300 μV. Overload input voltage is 0.25 V.
My idea is to build two channels, power it with separate HV windings of a toroidal transformer, and make separate GNDs for each channel.
Also, I would like to replace the 1 MΩ grid leak resistor with a series of 3 to make 1/10/100 attenuation of the input signal, so there will be no need for countless switching of the oscilloscope probes between this pre-amplifier and the digital oscilloscope.
What is your opinion? Is this a good idea?
