I want to make a wooden chess board that you can play on with regular pieces (i.e., not modified pieces that make use of RFID codes, magnets, …), but that is connected to a software that takes notice of my moves and acts as the second player.
I have been thinking about how to detect pieces on the board, and I have made the decisions that I do not need to recognize which piece is where: The "truth" is within the software, so if I move a piece from A to B, the software is able to find out which piece was moved.
So, I had the idea to drill two holes into each field of the chess board, one in the center, and one in the upper right corner:
- The one in the center will be used for a brightness sensor to detect whether a piece is standing on the field or not.
- The one in the corner will be used for an LED to show which piece the user has to move for the computer, so that the real-world situation matches the software situation again.
I want to use a Raspberry Pi as hardware foundation for the software to run, which will be written in Node.js (but that should not be important for this question).
So, what I end up with is 64 brightness sensors, and 64 LEDs, that I need to address individually. In other words: I need 64 outputs, and 64 inputs. And of course this is something a Raspberry Pi does not handle out of the box - and I think that there has to be a better way than to have 128 I/O ports.
Since I think that detecting the board's state is the more important task, I started to search the web how to handle a 8x8 matrix of switches. I found the suggestion to use a micro controller that scans the columns of the board sequentially, and in each columns detects whether a row (= a field) is used or not.
This would reduce complexity to having 8 outputs and 8 inputs (to be able to read the board's state).
On this, I have a few questions:
- Are my thoughts right, i.e. is this the correct approach, or is there a better alternative that I should watch out for?
- As I have no experience with micro controllers, what do I need to look out for? Do I just need a micro controller with 16 pins, that is programmable in a language that I am able to write, or …?
- Has anybody built such a board and has some advice or knows of a tutorial that walks you through the process?
