I have a doubt, when I have a circuit that has a driver for a serial interface, such as a TTL-to-RS485 or TTL-to-422 buffer. The typical situation I'm in is that this chip is connected on one side to an MCU and on the other side to a connector on the edge of the board. The question is, is it better to have the buffer as close to the MCU as possible or as close to the connector as possible? Reasoning in the first case (as close as possible to the MCU) I have the shortest possible 3.3V TTL line, so I minimize the noise on the MCU-BUFFER side. While in the second case (as close as possible to the connector) I favor the signals coming out of the connector. Which situation is the most advisable.
PS: the board is general purpose, so the environment is not defined a priori.
