This frequency has to remain constant. ???
You happen to have found an example where they choose this to be true, presumably from some application note you don't credit. It's a common way to use a DPLL, have a variable multiplication factor from some fixed, low noise, often crystal-derived reference.
However, the input reference frequency to your loop can have any value. 10 kHz to 100 kHz? No problem. In that diagram, replace '/N counter' with '/16 counter' (being pedantic should really be '/16 divider', and write 'minimum 10 kHz' next to Fref.
The stability of the loop depends on, amongst other things, the latency of your phase detector, which for a digital phase detector is proportional to the period of the reference frequency, worst at the minimum frequency. Normally if you have a loop bandwidth well below the lowest reference frequency, say 100 Hz for a 10 kHz Fref.min, then you can neglect this latency. If you want to push the loop bandwidth closer to Fref.min, say 1 kHz or more, then your loop filter must have less phase shift than a typical design would use, to accommodate this latency. If the loop is stable at the lowest frequency, you'll be fine at all higher frequencies.
