I am working on simulations of a 3rd order RC filter.
Cascaded first order RC lowpass X3 with: R = 100 ohms, C = 3.3 nF.
When I perform the calculations for the transfer function I get a result that is different from the theoretical which is just 3 cascaded 1st order RC filters.
Circuit: Circuit
Cascaded: Cascaded transfer function
Calculated: Calculated transfer function
When I simulate the circuit in LTspice and plot both the above equations in Matlab, the simulation matches the Cascaded formula.
LTspice Bode Plot, Cascaded
Versus: Bode Plot, Calculated
Am I deriving the transfer function incorrectly here or is it some other issue?
Full Calculations: Calculations 1 Calculations 2
    \$\begingroup\$ Your cascaded formula is wrong because it doesn't take into account the very significant effect of stage 2 loading stage 1 and, stage 3 loading stage 2. \$\endgroup\$
    Mar 15, 2023 at 13:29
  • \$\begingroup\$ @Andy aka, that's what I was thinking, but why does the LTspice simulation still match that (Cascaded) transfer function? I can provide the Matlab code too but it's simple and I'm fairly confident of no errors there. \$\endgroup\$
    – gallauj
    Mar 15, 2023 at 13:32
  • \$\begingroup\$ Your last step seems incorrect $$3 + 2\ c\ r\ s -(1+c\ r\ s) (2+c\ r\ s)^2 = -c^3 r^3 s^3-5 c^2 r^2 s^2-6\ c\ r\ s-1 $$ Looks like you flipped the minus to a plus. \$\endgroup\$ Mar 15, 2023 at 14:17
  • \$\begingroup\$ @SubaThomas That will do it. Figures it was a simple algebraic error in the end... On the last line too. Ran the expansion in Matlab and got the same as you. Bode Plot looks good now, thank you. \$\endgroup\$
    – gallauj
    Mar 15, 2023 at 14:29
Applying brute-force analysis to this type of circuit makes the exercise difficult, especially when it comes to tracking an error. I have used the fast analytical circuits techniques or FACTs to determine the transfer function (TF) of this circuit:
Then I compare the reference TF obtained using brute-force algebra versus the TF obtained with the FACTs: they are rigorously similar. Then, when you have components of similar values for \$C\$ and \$C\$, the transfer function simplifies:
In your attempt, you have wrongly cascaded the stages without accounting for the output impedance of the driving network. This is what I described in my brute-force approach by including two Thévenin generators. Then, you could have seen in the equation you came up with that for \$s\$ = 0, you do not find a magnitude of 1 as you should: open the caps in dc and the gain is 1.
The FACTs lead you to the answer by inspecting simple sketches - no algebra in this example - and that is the safest way to go in my opinion. Check out my seminar on the subject.
  • \$\begingroup\$ I don't know about your techniques, but what you're using is precisely known as the extended time constant method, formally known as Middlebrook's theorem. \$\endgroup\$
    – edmz
    Mar 23, 2023 at 22:44
  • \$\begingroup\$ The extra-element theorem or EET forged by Dr. Middlebrook is part of the FACTs. It has been generalized by a CalTech student many tears ago and lead to the technique I used in this example. This paper from Ali Hajimiri is an interesting read on the subject. \$\endgroup\$ Mar 24, 2023 at 6:22
Well, we have the following circuit:
When we use and apply KCL, we can write the following set of equations:
$$ \begin{cases} \begin{alignat*}{1} \text{I}_1&=\text{I}_2+\text{I}_3\\ \\ \text{I}_3&=\text{I}_4+\text{I}_5\\ \\ 0&=\text{I}_0+\text{I}_4+\text{I}_5\\ \\ \text{I}_2&=\text{I}_0+\text{I}_1 \end{alignat*} \end{cases}\tag1 $$
When we use and apply Ohm's law, we can write the following set of equations:
$$ \begin{cases} \begin{alignat*}{1} \text{I}_1&=\frac{\displaystyle\text{V}_\text{i}-\text{V}_1}{\displaystyle\text{R}_1}\\ \\ \text{I}_2&=\frac{\displaystyle\text{V}_1-0}{\displaystyle\text{R}_2}\\ \\ \text{I}_3&=\frac{\displaystyle\text{V}_1-\text{V}_2}{\displaystyle\text{R}_3}\\ \\ \text{I}_4&=\frac{\displaystyle\text{V}_2-0}{\displaystyle\text{R}_4}\\ \\ \text{I}_5&=\frac{\displaystyle\text{V}_2-\text{V}_3}{\displaystyle\text{R}_5}\\ \\ \text{I}_5&=\frac{\displaystyle\text{V}_3-0}{\displaystyle\text{R}_6} \end{alignat*} \end{cases}\tag2 $$
Now, we can use \$(2)\$ to rewrite \$(1)\$:
$$ \begin{cases} \begin{alignat*}{1} \frac{\displaystyle\text{V}_\text{i}-\text{V}_1}{\displaystyle\text{R}_1}&=\frac{\displaystyle\text{V}_1-0}{\displaystyle\text{R}_2}+\frac{\displaystyle\text{V}_1-\text{V}_2}{\displaystyle\text{R}_3}\\ \\ \frac{\displaystyle\text{V}_1-\text{V}_2}{\displaystyle\text{R}_3}&=\frac{\displaystyle\text{V}_2-0}{\displaystyle\text{R}_4}+\frac{\displaystyle\text{V}_2-\text{V}_3}{\displaystyle\text{R}_5}\\ \\ 0&=\text{I}_0+\frac{\displaystyle\text{V}_2-0}{\displaystyle\text{R}_4}+\frac{\displaystyle\text{V}_2-\text{V}_3}{\displaystyle\text{R}_5}\\ \\ \frac{\displaystyle\text{V}_1-0}{\displaystyle\text{R}_2}&=\text{I}_0+\frac{\displaystyle\text{V}_\text{i}-\text{V}_1}{\displaystyle\text{R}_1}\\ \\ \frac{\displaystyle\text{V}_1-\text{V}_2}{\displaystyle\text{R}_3}&=\frac{\displaystyle\text{V}_2-0}{\displaystyle\text{R}_4}+\frac{\displaystyle\text{V}_3-0}{\displaystyle\text{R}_6}\\ \\ 0&=\text{I}_0+\frac{\displaystyle\text{V}_2-0}{\displaystyle\text{R}_4}+\frac{\displaystyle\text{V}_3-0}{\displaystyle\text{R}_6}\\ \\ \end{alignat*} \end{cases}\tag3 $$
Now, when using Mathematica in order to solve this system of equations I found (I am assuming that \$\text{R}_\text{a}:=\text{R}_1=\text{R}_3=\text{R}_5\$ and \$\text{R}_\text{b}=\text{R}_2=\text{R}_4=\text{R}_6\$):
$$\mathscr{H}:=\frac{\displaystyle\text{v}_3}{\displaystyle\text{v}_\text{i}}=\frac{\displaystyle\text{R}_\text{b}^3}{\displaystyle\text{R}_\text{a}^3+\text{R}_\text{b}\left(\text{R}_\text{b}^2+\text{R}_\text{a}\left(5\text{R}_\text{a}+6\text{R}_\text{b}\right)\right)}\tag4$$
Applying this to your circuit we need to substitute \$\displaystyle\text{R}_\text{b}=\frac{1}{\text{sC}}\$, so we get:
\begin{equation} \begin{split} \mathscr{H}\left(\text{s}\right)&=\frac{\displaystyle\text{V}_3\left(\text{s}\right)}{\displaystyle\text{V}_\text{i}\left(\text{s}\right)}\\ \\ &=\frac{\displaystyle\left(\frac{1}{\text{sC}}\right)^3}{\displaystyle\text{R}_\text{a}^3+\frac{1}{\text{sC}}\cdot\left(\left(\frac{1}{\text{sC}}\right)^2+\text{R}_\text{a}\left(5\text{R}_\text{a}+6\cdot\frac{1}{\text{sC}}\right)\right)}\\ \\ &=\frac{\displaystyle\text{sC}\cdot\left(\frac{1}{\text{sC}}\right)^3}{\displaystyle\text{sC}\cdot\text{R}_\text{a}^3+\frac{\text{sC}}{\text{sC}}\cdot\left(\left(\frac{1}{\text{sC}}\right)^2+\text{R}_\text{a}\left(5\text{R}_\text{a}+6\cdot\frac{1}{\text{sC}}\right)\right)}\\ \\ &=\frac{\displaystyle\left(\frac{1}{\text{sC}}\right)^2}{\displaystyle\text{sCR}_\text{a}^3+\left(\frac{1}{\text{sC}}\right)^2+\text{R}_\text{a}\left(5\text{R}_\text{a}+6\cdot\frac{1}{\text{sC}}\right)}\\ \\ &=\frac{\displaystyle\text{sC}\cdot\left(\frac{1}{\text{sC}}\right)^2}{\displaystyle\text{sC}\cdot\text{sCR}_\text{a}^3+\text{sC}\cdot\left(\frac{1}{\text{sC}}\right)^2+\text{R}_\text{a}\left(\text{sC}\cdot5\text{R}_\text{a}+6\cdot\frac{\text{sC}}{\text{sC}}\right)}\\ \\ &=\frac{\displaystyle\frac{1}{\text{sC}}}{\displaystyle\left(\text{sC}\right)^2\text{R}_\text{a}^3+\frac{1}{\text{sC}}+\text{R}_\text{a}\left(5\text{sCR}_\text{a}+6\right)}\\ \\ &=\frac{\displaystyle\frac{\text{sC}}{\text{sC}}}{\displaystyle\text{sC}\cdot\left(\text{sC}\right)^2\text{R}_\text{a}^3+\frac{\text{sC}}{\text{sC}}+\text{sC}\cdot\text{R}_\text{a}\left(5\text{sCR}_\text{a}+6\right)}\\ \\ &=\frac{\displaystyle1}{\displaystyle\left(\text{sC}\right)^3\text{R}_\text{a}^3+1+\text{sCR}_\text{a}\left(5\text{sCR}_\text{a}+6\right)}\\ \\ &=\frac{\displaystyle1}{\displaystyle\text{s}^3\text{C}^3\text{R}_\text{a}^3+5\text{sCR}_\text{a}\text{sCR}_\text{a}+6\text{sCR}_\text{a}+1}\\ \\ &=\frac{\displaystyle1}{\displaystyle\text{s}^3\text{C}^3\text{R}_\text{a}^3+5\text{sCR}_\text{a}\text{sCR}_\text{a}+6\text{sCR}_\text{a}+1}\\ \\ &=\frac{\displaystyle1}{\displaystyle\text{s}^3\left(\text{C}\text{R}_\text{a}\right)^3+5\text{s}^2\left(\text{CR}_\text{a}\right)^2+6\text{sCR}_\text{a}+1} \end{split}\tag6 \end{equation}
So, when working out the bode plot we need to take a look at:
\begin{equation} \begin{split} \left|\space\underline{\mathscr{H}}\left(\text{j}\omega\right)\right|=&\left|\frac{\displaystyle1}{\displaystyle\left(\text{j}\omega\right)^3\left(\text{C}\text{R}_\text{a}\right)^3+5\left(\text{j}\omega\right)^2\left(\text{CR}_\text{a}\right)^2+6\text{j}\omega\text{CR}_\text{a}+1}\right|\\ \\ &=\frac{\displaystyle\left|1\right|}{\displaystyle\left|\left(\text{j}\omega\right)^3\left(\text{C}\text{R}_\text{a}\right)^3+5\left(\text{j}\omega\right)^2\left(\text{CR}_\text{a}\right)^2+6\text{j}\omega\text{CR}_\text{a}+1\right|}\\ \\ &=\frac{\displaystyle1}{\displaystyle\left|1-\text{j}\omega^3\left(\text{C}\text{R}_\text{a}\right)^3-5\omega^2\left(\text{CR}_\text{a}\right)^2+6\text{j}\omega\text{CR}_\text{a}\right|}\\ \\ &=\frac{\displaystyle1}{\displaystyle\left|1-\left(\omega\text{C}\text{R}_\text{a}\right)^3\text{j}-5\left(\omega\text{CR}_\text{a}\right)^2+6\omega\text{CR}_\text{a}\text{j}\right|}\\ \\ &=\frac{\displaystyle1}{\displaystyle\left|1-5\left(\omega\text{CR}_\text{a}\right)^2+\left(6\omega\text{CR}_\text{a}-\left(\omega\text{C}\text{R}_\text{a}\right)^3\right)\text{j}\right|}\\ \\ &=\frac{\displaystyle1}{\displaystyle\left|1-5\left(\omega\text{CR}_\text{a}\right)^2+\omega\text{CR}_\text{a}\left(6-\left(\omega\text{C}\text{R}_\text{a}\right)^2\right)\text{j}\right|}\\ \\ &=\frac{\displaystyle1}{\displaystyle\sqrt{\left(1-5\left(\omega\text{CR}_\text{a}\right)^2\right)^2+\left(\omega\text{CR}_\text{a}\left(6-\left(\omega\text{C}\text{R}_\text{a}\right)^2\right)\right)^2}} \end{split}\tag7 \end{equation}
And, let's set \$\displaystyle\alpha:=1-5\left(\omega\text{CR}_\text{a}\right)^2\$ and \$\displaystyle\beta:=\omega\text{CR}_\text{a}\left(6-\left(\omega\text{C}\text{R}_\text{a}\right)^2\right)\$, for the argument we get:
\begin{equation} \begin{split} \arg\left(\space\underline{\mathscr{H}}\left(\text{j}\omega\right)\right)&=\arg\left(\frac{\displaystyle1}{\displaystyle\left(\text{j}\omega\right)^3\left(\text{C}\text{R}_\text{a}\right)^3+5\left(\text{j}\omega\right)^2\left(\text{CR}_\text{a}\right)^2+6\text{j}\omega\text{CR}_\text{a}+1}\right)\\ \\ &=\arg\left(1\right)-\arg\left(\left(\text{j}\omega\right)^3\left(\text{C}\text{R}_\text{a}\right)^3+5\left(\text{j}\omega\right)^2\left(\text{CR}_\text{a}\right)^2+6\text{j}\omega\text{CR}_\text{a}+1\right)\\ \\ &=0-\arg\left(1-5\left(\omega\text{CR}_\text{a}\right)^2+\omega\text{CR}_\text{a}\left(6-\left(\omega\text{C}\text{R}_\text{a}\right)^2\right)\text{j}\right)\\ \\ &=-\displaystyle\begin{cases} \displaystyle0&\space\text{if}\space\displaystyle\alpha=0\space\wedge\space\beta=0\\ \\ \displaystyle\frac{\pi}{2}&\space\text{if}\space\displaystyle\alpha=0\space\wedge\space\beta>0\\ \\ \displaystyle\pi&\space\text{if}\space\displaystyle\alpha<0\space\wedge\space\beta=0\\ \\ \displaystyle\frac{3\pi}{2}&\space\text{if}\space\displaystyle\alpha=0\space\wedge\space\beta<0\\ \\ \displaystyle\arctan\left(\frac{\beta}{\alpha}\right)&\space\text{if}\space\displaystyle\alpha>0\space\wedge\space\beta>0\\ \\ \displaystyle\frac{\pi}{2}+\arctan\left(\frac{\left|\alpha\right|}{\beta}\right)&\space\text{if}\space\displaystyle\alpha<0\space\wedge\space\beta>0\\ \\ \displaystyle\pi+\arctan\left(\frac{\left|\beta\right|}{\left|\alpha\right|}\right)&\space\text{if}\space\displaystyle\alpha<0\space\wedge\space\beta<0\\ \\ \displaystyle\frac{3\pi}{2}+\arctan\left(\frac{\alpha}{\left|\beta\right|}\right)&\space\text{if}\space\displaystyle\alpha>0\space\wedge\space\beta<0 \end{cases} \end{split}\tag8 \end{equation}
Used Mathematica code:
In[1]:=Clear["Global`*"];
R1 = Ra;
R3 = Ra;
R5 = Ra;
R2 = Rb;
R4 = Rb;
R6 = Rb;
FullSimplify[
 Solve[{I1 == I2 + I3, I3 == I4 + I5, 0 == I0 + I4 + I5,
   I2 == I0 + I1, I1 == (Vi - V1)/R1, I2 == (V1 - 0)/R2,
   I3 == (V1 - V2)/R3, I4 == (V2 - 0)/R4, I5 == (V2 - V3)/R5,
   I5 == (V3 - 0)/R6}, {I0, I1, I2, I3, I4, I5, V1, V2, V3}]]
Out[1]={{I0 -> -((Rb (Ra + 2 Rb) Vi)/(Ra^3 + 5 Ra^2 Rb + 6 Ra Rb^2 + Rb^3)),
  I1 -> ((Ra + Rb) (Ra + 3 Rb) Vi)/(
   Ra^3 + 5 Ra^2 Rb + 6 Ra Rb^2 + Rb^3),
  I2 -> ((Ra^2 + 3 Ra Rb + Rb^2) Vi)/(
  I3 -> (Rb (Ra + 2 Rb) Vi)/(Ra^3 + 5 Ra^2 Rb + 6 Ra Rb^2 + Rb^3),
  I4 -> (Rb (Ra + Rb) Vi)/(Ra^3 + 5 Ra^2 Rb + 6 Ra Rb^2 + Rb^3),
  I5 -> (Rb^2 Vi)/(Ra^3 + 5 Ra^2 Rb + 6 Ra Rb^2 + Rb^3),
  V1 -> (Rb (Ra^2 + 3 Ra Rb + Rb^2) Vi)/(
  V2 -> (Rb^2 (Ra + Rb) Vi)/(Ra^3 + 5 Ra^2 Rb + 6 Ra Rb^2 + Rb^3),
  V3 -> (Rb^3 Vi)/(Ra^3 + 5 Ra^2 Rb + 6 Ra Rb^2 + Rb^3)}}
