In my project, I am using 12 solar cells in series as a power source. This is the link to the cell. Doing that will give me a power source of (3.6W * 12 = 43.2W) maximum and output voltage is (0.6 * 12 = 7.2V).
I want to use this source to power some sensors, such as this current sensor. I will power the sensors with 3.3V, therefore, I use this 3.3V DC/DC to get 3.3V. If I'm not wrong, the input current to the DC/DC should be milliamperes while my source can generate (43.2W / 7.2V = 6A) maximum.
mAs
I want to limit this current by using a resistor by connecting it to the input power pin of the DC/DC. Here are some questions I have at this point:
  1. Does the solution of using a current-limiting resistor sound like a potential solution to my problem?
  2. If so, how should I determine the value of the resistor? Should we look at the full load or no load current?
  3. Is there any other solution besides using a current-limiting resistor?
  • 6
    \$\begingroup\$ You don't have a problem. The 3.3V DC-DC converter will only draw as much current as it needs. \$\endgroup\$
    – Dave Tweed
    Mar 18, 2023 at 20:53
    \$\begingroup\$ I agree with @Dave, the converter certainly should ok safe to supply from a low-impedance source and the solar panels won’t supply more current than they can generate. Unless there’s a reason that you haven’t disclosed there’s no need to limit current in any additional way. \$\endgroup\$
    – Frog
    Mar 18, 2023 at 21:04
    \$\begingroup\$ A fuse might of course still be a good idea. Maybe a PTC polyfuse. \$\endgroup\$ Mar 18, 2023 at 21:26
  • \$\begingroup\$ Thank you. I will look at the PTC polyfuse as well. \$\endgroup\$
    – Alex
    Mar 18, 2023 at 21:40
I got the answer I wanted: There is no need for limiting current because the DC/DC will draw as much current as it needs.
