I'm designing an application in which the current running into a load is controlled by PWM. A microcontroller generates a PWM cycle at 20kHz and this signal is used to control a MOSFET which is directly connected to the load. The load absorbs 10A at 100% duty cycle, at 12V DC. The load is a thermoelectric module and the purpose of the circuit is to have a basic temperature control. No fancy features are required, just the easiest and wastless design approach. Which is the easiest configuration in order to achieve this? My basic understanding is that a pattern like MCU>mosfet driver>mosfet>load would be the best option. How could the "black box" mosfet driver + mosfet possibly be designed in order to minimize the number of components while keeping a low level of EMI and dissipated power?
    \$\begingroup\$ Use a MOSFET driver IC that is specified for gate drive requirements of the power MOSFETs, ergo minimum part count: Decoupling capacitors, a couple of resistors, that is it. The power MOSFETs should have protection diodes attached in reverse polarity, even if they have internal body diodes, else they may die: A common cause of MOSFET failure. For reducing wasted energy, drive MOSFETs hard into on / off state while transitioning in the respective direction, and minimize transition time - the longer the FETs stay in the knee part of their graph, the more power is wasted as heat. \$\endgroup\$ Commented Apr 17, 2013 at 13:14
Here's a circuit I did a few years ago that demonstrates a driver chip local to the MOSFET and an over-current protection in case the load shorted out. The MOSFET used is not as suitable as the BUK954 you mentioned on another question. I'd use that type for your job. enter image description here
The load is assumed to be purely resistive. In fact the original circuit had two MOSFETs driving a transformer with a centre-tap to the positive supply rail and it didn't need fly-back diodes (it used snubbers) but your's might need a protection diode across the load.
Circled in red is a local +5V power rail used for the over-current monitor - this can easily be derived locally with a small linear regulator such as 78L05.
Also note the big array of capacitors to the left of the circuit that absorbs most of the transient energy locally produced by switching the load. The original design was switching at 600kHz so if you wanted to run faster than 20kHz this shouldn't be a problem but i wouldn't go above 100kHz for the sake of efficiency.
