I need to find the input resistance of this circuit. There are two parts of this exercise:
  • The first one is to find the input resistance of the circuit without the capacitor.
  • The second is to the find the input resistance of the circuit with the capacitor ( C = 10 nF.)
It is not mentioned if the op-amp is ideal or not.
Do i make it by finding the equivalent impedance of R3, R4, C and R5?
I need to find the input resistance of this circuit. Do I make it by finding the equivalent impedance of R3, R4, C and R5?
It's slightly simpler than that. Because the -Vin input is a virtual ground, you can regard it as a short-circuit to ground and hence, R5 can be ignored. This then makes the input impedance: -
$$Z_{IN}\hspace{1cm}=\hspace{1cm}R_3 + X_C||R_4$$
This answer assumes an ideal op-amp.
Can you take it from here?
  • \$\begingroup\$ I didn't understand why the -Vin input is a virtual ground. isn't it supposed to have a voltage because of vs? \$\endgroup\$
    – Aleat
    Mar 21, 2023 at 11:21
    \$\begingroup\$ It's voltage will be the same as +Vin and.... because +Vin is connected to ground via R1 and R2, -Vin also will be at ground. If you haven't learnt about the term "virtual ground" then maybe you should look it up. I'll try and leave a link @Aleat \$\endgroup\$
    Mar 21, 2023 at 11:28
  • \$\begingroup\$ @Aleat what should I do when someone answers my question \$\endgroup\$
    Mar 21, 2023 at 11:35
    \$\begingroup\$ Do you understand my answer; did you follow the concept of the virtual ground? \$\endgroup\$
    Apr 9, 2023 at 10:10
