I have a stereo potentiometer (10 kΩ) and a +5 VDC voltage (regulated by a 7805) with which I am trying to generate two "inverse" voltages, so at the same time one channel being high resistance and the other low resistance ie. channel one 5 V and channel two 0 V, or channel one 2.5 V and channel two 2.5 V. I hope you get it.
I then want to buffer these voltages with a TL072. The op-amp is overheating and I have a feeling that the power supply does not like what I do either. The load impedance is around 4.7 kΩ, which shouldn't be the problem. But what is?
This how I hooked it up:
