I designed a complete H-bridge using four MOSFETs, to be able to control the supply voltage of a Peltier cell. I put a 1 μH coil in series with the Peltier to work as a small filter and I use an INA current sensor op-amp from Texas Instrument to measure the current going into the H-bridge. The PWM frequency is 2.5 kHz.
The circuit works fine but the coil gets very hot, and when I look at the output signal of the current sensor I see that 10 A spikes appear when the signal of the PWM goes from 0 to 24 V. I don't understand why that peak current of 10 A appears when the Peltier cell has a maximum consumption of 7 A according to its data sheet (the Peltier cell continues to work correctly after having tested the circuit for 1 full week without being turned off).
I decided to completely filter the PWM signal to get a constant voltage proportional to the PWM duty cycle, so I put in an LC filter, did some simulations, and got acceptable values for the inductance and the capacitor. The problem is that the ripple current of the capacitors is a bit high. Can I use X8L ceramic capacitors instead of the electrolytic ones?
As I mentioned, I had to simulate a bit to find the values but I remember that there are formulas to theorize the ripple current of the capacitors, the values of the capacitor and the coil, and others. Where can I find information for this type of filter? Is the theory for designing LC filters for AB amplifiers valid here?
In the simulation, increase the frequency of the PWM signal to 80 kHz; that will be the new frequency that I will use in the new design.
