I'm working on a project that needs to drive a single speaker. I've used LM2879T chips in the past to drive two speakers, so I have a couple extra I'm trying to use for this single speaker project.
Since I'm using a single speaker, I've heard I should 'bridge' the two outputs of the amplifier. From the datasheet, it gives this example circuit. Maybe it is a silly question, but I'm not sure where I'm supposed to attach the speaker in this scenario. My best guess is that it takes the place of RL, but I wanted to check with others first.
Elsewhere in the datasheet, it gives this example for a typical two speaker setup, and it is fairly obvious where the speakers go.
Again, I'm using this chip just because I have it on hand. I've been eyeing some better options I would go for instead if this chip isn't worth it.
Thanks for any help!
