I am simulating a circuit to model the EN 61000-4-4 waveform for electrical fast transients using LTspice. The idea is to have the generator for some in house testing.
After a lot of back and fourth with @Andy aka and @Tim Williams (special thank you to both of them) I decided to use the schematic of the generator provided by the test standard IEC61000-4-4.
After a few hours of figuring out the parameters I have somewhat of a satisfactory simulation.
This is my circuit, I am using an ideal switch and here is where my problem is. I would like to have some help picking a good switch in order to get close to the standard's requirements. In addition, if there are any suggestions to be made regarding my circuit, I welcome them.
The following probing nodes have been added: EFT_output / Energy_storing_capacitor / Pulse
Here are the results the probed nodes:
The switch starts conducting with no delay :
This is the output voltage, the rise time is 221ps due to the fact it is an ideal switch
As we can see the amplitude satisfies the requirements of the standard.
