I'm trying to create an op-amp circuit that attenuates a 5 V input signal down to a 1 VRMS Vout signal (1.414 V Vout).
I need to shift the output signal by 2.5 V so that it can be fed into a unipolar ADC.
Below is my current inverting op-amp circuit in Multisim:
As can be seen above, the Vout signal amplitude is spot on: (4.6338 - 1.7895) / 2 = 1.422 V (roughly 1.414 V).
The problem is that the blue Vout signal appears to have shifted much further than expected. The midpoint should be on the purple 2.5 V line but it is actually at (4.6338 + 1.7895)/2 = 3.211V.
Does anyone have any idea what's causing the unexpected voltage shift, and how to fix it?
