In my project I make use of 3 PWM I²C-boards, each having 3 x 16 pin connectors. My initial thought was to use jumper connectors to connect LEDs to the pins but they are not reliable enough.
I would rather not de-solder 144 (3x16x3) pins, Is there a connector that can securely connect to these pins?
Wishlist:
- If at all possible, no de-solder of existing pins on board.
- Secure connection (mild vibrations occasionally)
- 48/24/12/3-pin connector, all acceptable
- No pre-made connector wire. I want to be able to tailor-make the wire length
- Screw terminal is ok but not at all required
- Connector available to buy in Europe/Sweden
my background:
- beginner in electronics, hence the aversion to de-solder 144 pins. its gonna take me a year!
- beginner in electronics, so if the solution / connector is blatantly obvious, please have patience with me. I looked at TME and Mouse websites and there is literally a million different connectors available but I lack knowledge to find a fitting connector.
