I have two systems I am trying to get to work together.
One system has two inputs, input 1 takes an output from a potentiometer with a voltage ranging from 0.9 V - 4.5 V using a supply reference voltage of 5 V. The second input takes an output from a potentiometer ranging from 0.45 - 2.25 V. The output of the second potentiometer is always half the output from the first potentiometer. For safety reasons these inputs must remain independent.
These potentiometers are always physically locked together so that when one moves, the other one does too. The voltage from pot 2 is always half of pot 1 unless there is a failure. We will call this potentiometer assembly 1.
I am trying to interface with a different potentiometer, due to physical constraints I cannot use a potentiometer assembly other than this one. We will call this potentiometer assembly 2. This potentiometer assembly works just like the assembly 1 but the value of output 2 is inverted, meaning as the pot is actuated the output #2 goes from 4.5 V to 0.9 V, the oposite of what is needed. Reversing the input wires of the pot does not work. If you add up the voltage outputs of assembly 2 they will always add up to 5 V unless something has failed.
So here is a description of what I need: a circuit that creates two independent outputs from two independent inputs. input number one will receive 0.9 - 4.5 V. Input number two will receive 4.5 - 0.9 V. The voltages of the inputs will always add up to 5 V unless something has failed. failure of the input voltages to add up to 5 V should cause the outputs to go to 0 V. output number one voltage should be equal to input number one. Output number 2 should always output half the voltage of output number one unless the combined voltage from the inputs deviates from 5 V. If a deviation happens then the circuit should be in a fail state and drop all output voltage to 0
