Is it possible to convert a 250 kΩ potentiometer to 500 kΩ or a 500 kΩ stereo potentiometer to mono?
I am finding it difficult to locate a 500 kΩ mono potentiometer.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityIs it possible to convert a 250 kΩ potentiometer to 500 kΩ or a 500 kΩ stereo potentiometer to mono?
A 500k stereo pot could be used for mono, it's just two pots ganged together so you'd only connect one of the pots in it. It would need to physically fit though, a stereo pot is generally going to be larger than a mono one.
You also have to make sure you get the correct taper. Pots come in different tapers, such as linear where the resistance changes evenly as you turn the shaft, or audio where the change in resistance is roughly logarithmic to match our hearing response. Volume controls are usually audio taper, tone controls might be linear if they're the cut/boost type where center position is flat response.
You might be able to get away with a 250k pot for volume, although it may affect the overall sound as it changes the impedance the pickups and amp see, to use one for tone the capacitor values would also need to be changed. If you have some on hand you could try it, if you're buying new ones you'll want to stick with the original values.
