I'm using Altium Designer to design a 4-layer PCB. In the power supply region (230 VAC power lines to an AC-DC converter), I'm routing exclusively on the bottom layer, and have added a rule to maintain a good amount of clearance around those high-voltage (HV) nets. This works fine for the polygon pour on the bottom layer, but the polygon pours on the remaining 3 layers are filled with copper that passes directly above the HV traces. The following image illustrates this:
What I want to achieve is for the polygon pour clearance to extend to all 4 layers, but without adding traces to the remaining 3 layers. The following image illustrates what I want to do:
I managed to do this by temporarily setting the HV traces as multi-layer, repouring and then resetting the HV traces to bottom layer only. The problem is that if I now repour again, all layers other than the bottom will again be filled with copper in the HV regions.
Is there a way to achieve the above effect in Altium Designer?
Edit — Some additional information
I can achieve what I want from an electrical perspective, by simply avoid pouring over the mains (HV) section altogether (using a Keep-Out region or drawing around it). The main reason I prefer to follow the "clearance across all layers" approach, as illustrated in the second image above, is because it maintains an even copper distribution across all layers, thus allowing for a better mechanical bonding and long-term stability of the 4 copper layers, 2 prepregs and dielectric in between (no large copper vertical gaps, especially at the edges of the PCB, where the mains section is usually located). I also find the "clearance across all layers" approach very elegant, in that it dynamically adapts to any placement/routing modifications that may happen in the future. I find it useful in general, and relatively simple to implement programmatically in Altium Designer, and was (still is) hoping for a simple solution, based on some clever use of rules in the PCB.
