7
According to here, the PCI Express TLP (Transaction Layer Packet) can target 4 different address spaces.
My question is about the IO and memory address spaces.
As we know, the PCI specification was first developed by Intel. And Intel's x86 processor has 2 major address spaces: IO and memory. I think that's why the PCI Express transactions can target 2 kinds of locations in system IO map and system memory map. Is it some kind of x86-specific lineage?
But how about ARM-based system? AFAIK there's no IO address space for ARM processors.
Does that mean the PCI Express IO address space is meaningless for ARM-based system?
Thanks.
ADD 1 --- 9:18 2023/4/19
A related thread: https://stackoverflow.com/questions/75265993/is-pci-cf8h-cfch-io-port-addresses-only-applicable-to-processors-with-an-io-ad
Some quote:
The method for generating configuration cycles is host dependent. In IA machines, special I/O ports are used. On other platforms, the PCI configuration space can be memory-mapped to certain address locations corresponding to the PCI host bridge in the host address domain.
ARM-based systems that fully support PCI spec still support I/O transfers. The I/O space is then mapped into memory somewhere.
    \$\begingroup\$ I haven't looked at the implementation, but the ARM Firmware Suite Reference Guide does have functions such as uHALr_PCIIORead32 to access I/O space. \$\endgroup\$ Apr 3, 2023 at 17:29
  • \$\begingroup\$ This is exactly what I was thinking. I will elaborate about it later. \$\endgroup\$ Apr 4, 2023 at 8:22
  • \$\begingroup\$ @ChesterGillon Yep, IIRC these are the requisite memory-mapped accesses wrapped in an interface that clearly indicates the intent. \$\endgroup\$ Apr 4, 2023 at 16:48
Yes. The I/O address space support is included for x86, and ARM does not even have instructions to access such a separate address space.
Even in the x86 world, the I/O space was never extended beyond the 16-bit limit, and almost all PCIe "I/O" ranges are memory mapped. The only PCIe devices that support the I/O space do so because they need to be compatible with old x86 devices such as (non-USB) serial/parallel port or VGA.
