I'm trying to add two numbers together, and it's giving an odd result.
Here's the code,
`timescale 1ns / 1ps
module addition_test(
input clk,
output reg [31:0] probe_00, probe_01
reg [31:0] a, b;
reg sel;
always @(posedge clk)begin
    case(sel)
        1'b0 : begin
            a <= 15;
            b <= 5;
            sel <= 1'b1;
        end
        1'b1 : begin
            probe_00 <= {a[1:0],a[31:2]}^{a[12:0],a[31:13]}^{a[21:0],a[31:22]};
            probe_01 <= {a[1:0],a[31:2]}^{a[12:0],a[31:13]}^{a[21:0],a[31:22]} + b;
        end
        default : begin
            sel <= 1'b0;
        end
    endcase
end
endmodule
probe_00 evaluates to C0783C03 as expected, but probe_01 evaluates to C0783C06, which is off by 2. I expect probe_01 to be C0783C08.
I've tried simulating this with both Vivado and iverilog, and tried both blocking and nonblocking assignments, and I still get the same result.
Can anyone tell me what I'm doing wrong here?
$display("%b",b);
probe_00 = a[1:0],a[31:2]}^{a[12:0],a[31:13]}^{a[21:0],a[31:22]};
probe_01 = {a[1:0],a[31:2]}^{a[12:0],a[31:13]}^{a[21:0],a[31:22]} + b;
gives: 00000000000000000000000000000101. That is the entirety of my code, except for my testbench, which only inputs the clock and takes the output from addition_test().
  • \$\begingroup\$ Hope b did not change elsewhere in your code. Can you print the value of b using $display just at the point where the addition is happening? \$\endgroup\$
    – sai
    Commented Apr 8, 2023 at 2:13
Your problem is the add+ operator has higher precedence than the xor ^ operator. Put parentheses around the expression
probe_01 <= ( {a[1:0],a[31:2]} ^ {a[12:0],a[31:13]} ^ {a[21:0],a[31:22]} ) + b;
See Table 11-2—Operator precedence and associativity in the IEEE 1800-2017 SystemVerilog LRM
