This post is a continuation of this question.
LTspice recently introduced a new feature called frequency response analyzer, see the image below.
The green box shows the symbol for FRA. If you click on the FRA the second image pops up for configuring the FRA. Then if you click on 'Help me to configure this for a switching regulator', the third window comes.
I have some questions regarding the third window.
How do I get Approximate Closed-Loop Bandwidth of a switching regulator? Is this information available in the datasheet?
From where I will get Approximate common mode voltage at FRA device?
As per Lars' answer, the part circled in yellow is the rise time. Please correct me if I am wrong.
