QUESTION:
I'm having a hard time figuring up what the Thevenin Voltage is along with Thevenin Resistance for this circuit below. I'm also confused on what I'm suppose to do when there is a current source thrown in or multiple sources of any kind thrown in. Do I convert them all to voltage sources before I even start figuring Thevenin Equivalent?
I arrived at the following answers. If they are wrong could you provide a brief explanation on how you figured each answer and a solution to my last question above.
R (TH) = 1.57K ohms V (TH) = 44.8 Volts
NOTE: I didn't know how to enter the Load Resistor in my Simulator. Therefore the break in the circuit on the far right is where it's placing the Load Resistor at.
