Assume a network consisting of N number of resistors, dependent current sources and voltage sources also independent current sources and voltage sources (ideal). Now the current across one particular resistor is I Amps. To get 2I Amps which one of the following would be appropriate?
A] Double the independent voltage sources.
B] Double the independent current sources.
C] Double the values of dependent current sources and voltage sources.
D] Double values of both independent current and voltage sources.
E] Can't be determined.
How the current relates to dependent or independent voltage source here?
