enter image description here Updated Schematic enter image description here I am trying to set up an external battery storage for solar lights as the solar lights are not in direct sunlight and cannot charge their own batteries.
Each solar light runs off a single 1.2v AA rechargeable Ni-Mh battery.
I have put together 4 18650 cells in parallel. They run into a TP4056. The BMS branches from the negative input terminal to a s8550 to act as an auto on/off switch using the solar panel as a light sensor. The output of the TP4056 runs to a LM2596S stepping the input voltage of 4.2V to 1.26V.
My trouble is, with the LM2596S in place the bulb illuminates very low. But when I remove the s8550 from the circuit the light shines brightly the way it should.
Is there something I can replace the s8550 with as I feel it's the problem reducing my current?
Datasheet URLs S8550 https://www.mouser.com/datasheet/2/149/SS8550-118608.pdf LM2596S https://www.ti.com/lit/ds/symlink/lm2596.pdf TP4056 https://www.addicore.com/TP4056-Charger-and-Protection-Module-p/ad310.htm
    \$\begingroup\$ Please provide a schematic, and indicate how much current the light draws. \$\endgroup\$ Commented Apr 14, 2023 at 17:27
  • \$\begingroup\$ Links to datasheets for your components would also help make this question better and attract more quality answers. \$\endgroup\$ Commented Apr 14, 2023 at 19:33
  • \$\begingroup\$ Sorry I am new to this stuff. I've added a schematic and the light draws .97ma. \$\endgroup\$
    – NateA
    Commented Apr 14, 2023 at 21:53
  • \$\begingroup\$ ”TP4056 BMS” TP4056 is not a BMS but a linear CC/CV charger IC. \$\endgroup\$
    – winny
    Commented Apr 14, 2023 at 22:36
  • \$\begingroup\$ @winny thank you. Noted👍 \$\endgroup\$
    – NateA
    Commented Apr 14, 2023 at 23:01
Use the enable pin of the LM2596S to turn on your 1.2 V output when solar is low.
Please note that this is not a complete schematic but rather more of a glorified block diagram.
Resistor divider R3/R4 is added on case your open circuit voltage on the solar panel is above 6 V. "5 V" solar panels are never 5.0 V. Adjust as needed, preferably with a potentiometer until it turns on at reasonable low light level.
  • \$\begingroup\$ thank you for the help with this. I updated my schematic to show what I have done, but I am still having a problem. I must be doing something wrong or missing something. I am using a 1.2V battery in place of the solar panel for testing but when I connect to pin1 the voltage on the LM2596S drops to 0 which is perfect. But when I remove the 1.2V battery simulating no voltage from the solar panel the 18650 battery does not kick in and I have to pull the 18650 to reset everything. \$\endgroup\$
    – NateA
    Commented Apr 18, 2023 at 2:12
  • \$\begingroup\$ would it be possible to just use a different transistor instead of the S8550? Something that can handle 1a of current like the BC639? components101.com/transistors/…. \$\endgroup\$
    – NateA
    Commented Apr 18, 2023 at 20:24
