I'm making a quadcopter with two little grabber arms. Here's the relevant hardware I currently have:
- 1500mAh 100c 14.8V (4s) lipo battery
- 2s-6s flight controller that's rated for 45A burst current (times 4 motors) = 180A max
- 5V OpenRB-150 servo controller that powers 6 small servos drawing maximum 10A (together)
- 11.1V power supply to 6 servos drawing maximum 10A (together)
From what I've gathered on forums is that I should connect a busbar to the battery and connect some DC/DC converter to the busbar to the different controllers/servos according to their voltage.
Wouldn't the busbar divide the voltage between the converters and/or cause noise or something? I'm an electricity novice and this is the first time I'm making a robot at this detailed level.
I've also read about PDB's, but they seem like overkill because I'd have to get a giant PDB that would provide 180A to the FC from one of the terminals when the the other controller and servos only need 10A each.
