I'm trying to repair an old stereo and I'm fairly sure I blew one of the components. I've never seen one of these before, and after research here and there I can't identify what it is - it's this cap looking silver thing in the center of the pictures:
So it's not a cap, it has 75000 written on the side of it and Y101 on the board, if that's any help.
    \$\begingroup\$ Guessing: oscillator crystal. Can't read the markings. Does the "stereo" feature a clock? \$\endgroup\$
    – greybeard
    Commented Apr 22, 2023 at 9:22
  • \$\begingroup\$ As I suspected, it took a split second to any trained paid of eyes. Thanks a lot to all of you :-) \$\endgroup\$
    – Philippe
    Commented Apr 22, 2023 at 10:52
  • \$\begingroup\$ @greybeard yes it does :-) \$\endgroup\$
    – Philippe
    Commented Apr 22, 2023 at 10:55
  • \$\begingroup\$ A crystal is unlikely to show visible evidence of failure. Why do you believe that it has failed? \$\endgroup\$
    – Mattman944
    Commented Apr 22, 2023 at 15:45
  • \$\begingroup\$ @Mattman944 because I applied too much voltage on the wrong pin (8v), the board drawn about 3 amps for a few seconds then smoke escaped from it, or at least I assumed it was from there. \$\endgroup\$
    – Philippe
    Commented Apr 22, 2023 at 16:34
It is most probably a 75kHz crystal, check if it is connected to pins 78 and 79 of Valence AP702 controller.
  • \$\begingroup\$ You are very correct sir, after having a look at the datasheet's schematics, this is precisely what is connects to. And I've also learned now how to figure this out by myself next time, many thanks! \$\endgroup\$
    – Philippe
    Commented Apr 22, 2023 at 11:11
It is a tuning fork style crystal resonator in a cylindrical can. The designator Y101 indicates that as well.
Something like this.
It looks like a crystal to me.
From wikipedia: enter image description here
https://en.wikipedia.org/wiki/Crystal_oscillator#/media/File:Crystal_Packages.jpg
