I'm simulating the following circuit in PySpice:
In this configuration, the N-JFET is always in saturation mode, as you can see by the plot of Vds - (Vgs - Vto) = Vds - Vgt, which is always positive:
Voltage Plots
Hence, the value of Id should be given by the following equation, according to the S&H model:
$$ I_d = 0.5 \beta (V_{gs} - V_t)^2 (1 + \lambda V_{ds}) $$
However, when I compare the value of the measured Id = (Vdd - Vd) / Rd to the one calculated from the formula above, I get the following mismatch:
Could anybody help me on what I missed here? Below you can find the Python code:
import numpy as np
import matplotlib.pyplot as plt
from PySpice.Spice.Netlist import Circuit
from prefixed import Float
def main():
    F0 = 20  # [Hz]
    FS = 48000  # [Hz]
    temp_c = 20  # [celsius]
    A = 1.0  # [V] amplitude, linear
    T = 0.1  # [seconds]
    # Spice circuit, based on the LSK189A from LTSpice
    circuit = Circuit('JFET')
    LSK189A = circuit.model("LSK189A", "NJF",
                            Beta="2.2m",
                            Betatce="-0.5",
                            Vto="-1.13",
                            Vtotc="-2.5m",
                            Lambda="4.3m",
                            Is="3f",
                            Xti="0",
                            Isr="0",
                            Alpha="30u",
                            N="1",
                            Rd="11",
                            Rs="30",
                            Cgd="3.19p",
                            Cgs="2.92p",
                            Fc="0.5",
                            Vk="120",
                            M="320m",
                            Pb="0.8",
                            Kf="0.0009f",
                            Af="1",
                            Gdsnoi="2.15",
                            Nlev="1",  # changed from original 3
                            Mfg="Linear_Systems",
    # component values
    Vdd = 9.0
    Rg = 1E6
    Rd = 4.4E3
    Rs = 1E3
    # Netlist
    circuit.V('Vdd', 'vdd', circuit.gnd, Vdd)
    circuit.SinusoidalVoltageSource(
        'in', 'gate', circuit.gnd, amplitude=A, frequency=F0)
    circuit.R('Rg', 'gate', circuit.gnd, Rg)
    circuit.R('Rd', 'vdd', 'drain', Rd)
    circuit.R('Rs', 'source', circuit.gnd, Rs)
    circuit.J('JFET', 'drain', 'gate', 'source', model="LSK189A")
    jfet_spice_params = {
        p.upper(): LSK189A._parameters[p]
        for p in LSK189A._parameters
    plt.figure()
    plt.title('Id x t')
    # Spice model
    simulator = circuit.simulator(
        temperature=temp_c, nominal_temperature=temp_c)
    # analysis = simulator.dc(Vin=Vsl)
    analysis = simulator.transient(step_time=1/FS, end_time=T)
    y_id_spice = (np.array(analysis["vdd"]) - np.array(analysis["drain"])) / Rd
    y_vgt_spice = np.array(
        analysis["gate"]) - np.array(analysis["source"]) - Float(jfet_spice_params["VTO"])
    y_vds_spice = np.array(analysis["drain"]) - np.array(analysis["source"])
    # if > 0 then saturation
    y_limit_spice = y_vds_spice - y_vgt_spice
    t = np.array(analysis.time)
    plt.plot(t, y_id_spice, label="Id_spice")
    Id_spice_calc = (1 + Float(jfet_spice_params["LAMBDA"]) * y_vds_spice) * 0.5 * Float(
        jfet_spice_params["BETA"]) * y_vgt_spice**2
    plt.plot(t, Id_spice_calc, label="Id_spice_calc")
    plt.xlabel('T [s]')
    plt.ylabel('Id [A]')
    plt.margins(0, 0.1)
    plt.grid(which='both', axis='both')
    plt.legend()
    plt.figure()
    plt.title('V x t')
    plt.plot(t, y_vgt_spice, label=f"Vgt")
    plt.plot(t, y_limit_spice, label=f"Vds-Vgt")
    plt.xlabel('T [s]')
    plt.ylabel('V [V]')
    plt.margins(0, 0.1)
    plt.legend()
    plt.show()
if __name__ == "__main__":
    main()
  • \$\begingroup\$ Did you try messing around with the threshold voltage? \$\endgroup\$
    Apr 24, 2023 at 17:10
  • \$\begingroup\$ No I haven't. Vto is a fixed SPICE parameter. I did try with different NJT models though. The mismatch was also there. \$\endgroup\$
    – edwillys
    Apr 24, 2023 at 17:24
  • \$\begingroup\$ What is Vgt? Did you mean Vgs? \$\endgroup\$
    – Ste Kulov
    Apr 24, 2023 at 20:01
    \$\begingroup\$ Vgt = Vgs - Vt \$\endgroup\$
    – edwillys
    Apr 24, 2023 at 20:08
    \$\begingroup\$ @edwillys W and L are only used for MOSFETs...at least in SPICE. Anyway, I think the problem is if someone says they're using the Shichman-Hodges (or any) model for something (anything), you need to see how they explicitly implement it and define the parameters. For SPICE it's implemented a certain way, and the transconductance parameter is different between JFETs and MOSFETs. Besides the textbook mentioned in the answer below and the ngspice manual, you can also take a look at the original SPICE2 thesis for the implementation: www2.eecs.berkeley.edu/Pubs/TechRpts/1975/9602.html \$\endgroup\$
    – Ste Kulov
    Apr 27, 2023 at 2:05
The 0.5 factor should not be there in your calculation. See 3-22 page 143 of 2nd edition Semiconductor Device Modeling With Spice (Guiseppe et al.) which is the same equation as you have but the 0.5 has been rolled into \$\beta\$.
The remaining discrepancy in the static model is mostly accounted for by Rs (30Ω in the 'A' bin model), which reduces Vgs.
I presume the 'B' model is intended to be closer to typical with 'A' and 'C' representing outliers..
    \$\begingroup\$ Hmmm...I noticed the same thing as you, but there still remains a discrepancy. i.sstatic.net/5HhU4.png \$\endgroup\$
    – Ste Kulov
    Apr 24, 2023 at 22:42
    \$\begingroup\$ Oh, I think I understand now. I had to dissect the Python code to figure it out. He's using the Vds and the Vgs values calculated via the SPICE engine where Beta=2.2m, but then he's using those values along with the wrong Beta=1.1m to calculate Ids. Changing the Python code to remove the *0.5 factor and make Rs=0 is confirmed to have the plots line right on top of each other. i.sstatic.net/rWlNX.png \$\endgroup\$
    – Ste Kulov
    Apr 25, 2023 at 1:59
    \$\begingroup\$ I don't know what the A B C are, I just see that they're available models at the manufacturer and don't line up with any known designations on the parts. There is a very wide range of possible Idss and if you look at the Idss for each of the models you get 2.6mA, 5.6mA, 10.8mA respectively. Datasheet limits for Idss are 2.5mA and 15mA with 5mA typical, so the B model is closest to typical. Rd doesn't make nearly as much difference as Rs because it doesn't affect Vgs. \$\endgroup\$ Apr 25, 2023 at 13:27
    \$\begingroup\$ @edwillys If you don't have access to the book you can take a look at Equation 9.5 in Section 9.2.2 of the ngspice manual: ngspice.sourceforge.io/docs.html \$\endgroup\$
    – Ste Kulov
    Apr 25, 2023 at 16:32
    \$\begingroup\$ @edwillys Also, you may be able to directly access Semiconductor Device Modeling With Spice, 2nd ed.. \$\endgroup\$ Apr 30, 2023 at 23:42
