Overall I'm working on a single-phase full bridge inverter, but before I implement the full bridge I wanted to start with a simpler circuit. Below I have a circuit diagram of the half-bridge circuit I'm using. And I'm trying to drive the MOSFETs using the IRS21084 half-bridge driver. I’ve looked at and followed the advice of some of the design and application sheets from Infineon on how to implement the circuitry of the gate driver, but I'm having a major issue. The issue is that I'm getting an output voltage of about 15 V at the high-side gate driver output (HO) and about 6 V from the low-side gate driver output (LO). If I'm not mistaken the correct output should be the same for both the high and low sides. This is troublesome because the low-side output voltage is not going to be able to turn on the low-side MOSFET and overall the half-bridge won't work.
The following is a brief explanation of how I have set up and configured the IRS21084 half-bridge driver.
- I’m providing a constant 15 V with the LM317 for the supply voltage (VCC)
- I’m using the teensy 3.5 microcontroller to provide a PWM input at 20 kHz for both the HIN and LIN pins.
- I’m using a 100 kΩ resistor for the dead time.
- For the bootstrap diode, I'm using the UF4007 from Vishay. It has a reverse recovery time of 75 ns and a voltage drop (Vf) of 1.7 V.
- For the bootstrap capacitor, I followed the DT04-04 application sheet from Infenion called ‘Using Monolithic High Voltage Gate Drivers’ and ended up with a capacitor value of 2.2 uF. I used a ceramic capacitor.
- For both the decoupling capacitor, and the bypass capacitor, I couldn't find any information on how to determine the values for them, so I used the same value capacitor from the bootstrap, for both decoupling and the bypass capacitor.
When testing the gate driver circuit does it need to be connected to the bridge circuit? Also, how do I determine the values of Vge-min and Vce-on for my circuit? For the bootstrap circuit do I need to include a bootstrap resister if so, how would determine the value for it? I used ceramic capacitors for all three capacitors, does that affect the circuit in any way or do I use different types of capacitors for the decoupling or bypass capacitors?
Lastly below are the provided datasheets of the components I'm using 91188.pdf (vishay.com) uf4001.pdf (vishay.com) IRS2108-IRS21084 (S)PbF (infineon.com) https://www.infineon.com/dgdl/Infineon-Using_Monolithic_Voltage_Gate_Drivers-AN-v01_00-EN.pdf?fileId=5546d462584d1d4a01585242c11947b1
