Circuit:
I would like to cut off the power to my APA102-LED-strip during uC sleep - as the standby current of these strips is relative high.
The strip is directly powered via the 5 V from the USB powerbank. Theoretically it can draw up to 2.4 A@5 V = 12 W. In normal usage it will be ~1 A (5 W) The uC (ESP32-S3) is a 3.3 V type. I think I need a high-side switch for the LED-power path.
So I need a P-channel MOSFET with 3.3 V logic level and ~3 A or similar. For this I found at my available/favorite reseller (reichelt.de)
First two labeled as logic level - third just found by price sorting.
Am I correct with my assumptions that all of these would work? Am I missing something? Every time I have to select MOSFETs I have to relearn how to read these datasheets properly and find the correct VDSon information. So I am looking forward to some educational answers ;-)
