I am taking the Control Systems course in high school and the teacher gave as the first exercise to make a 3 floor elevator.
To make the elevator, 3 push buttons must be used, one to go to the second floor, one to go to the second floor and one to go to the third floor, there is also 1 limit switch on each floor and finally 1 lamp on each floor that is activated when it is on that floor. Only relays / contactors can be used to make the logic circuit.
I was able to realize the elevator without many problems, but I would like to know if there is a way to simplify the logic of my circuit, because I use 14 relays and I do not think it is necessary to use so many.
Here is the photo of the circuit: enter image description here
P1 is the first floor push button, P2 is the second floor push button and P3 is the third floor push button.
FC1 is the first floor limit switch, FC2 is the second floor limit switch and FC3 is the third floor limit switch.
    \$\begingroup\$ You've explained everything except the rules of the components you can use. Are they: just relays, switches and lamps? (Please edit this into your question, don't answer in comments.) \$\endgroup\$
    – TonyM
    Commented May 1, 2023 at 20:50
  • \$\begingroup\$ It would have been much easier to read this as a ladder diagram rather than a wiring diagram :) \$\endgroup\$ Commented May 1, 2023 at 21:03
  • \$\begingroup\$ Have you assembled this circuit, or only ran it in a simulator? \$\endgroup\$ Commented May 1, 2023 at 21:09
  • \$\begingroup\$ @Kubahasn'tforgottenMonica We have not yet learned ladder. \$\endgroup\$ Commented May 1, 2023 at 21:13
  • \$\begingroup\$ I only tested it in the simulator, I didn't put it together in real life. \$\endgroup\$ Commented May 1, 2023 at 21:14
Number of relays isn't always a problem. This is an elevator. Wires will be long. And the switches must be reliable and have a long life.
So, for example, instead of P1 controlling K1 and two NO contacts, P1 could be a DPST switch. But instead of just one wire (not counting the common), now you need four wires, and it's harder to troubleshoot the circuit, and you have to use more expensive switch that has mechanically linked contacts so that there's no invalid state due to a failure of a single contact. Safety relays with mechanically linked contacts are a reasonable alternative here.
Also, keep in mind that the cost of the relays is a minuscule part of the initial cost of an elevator. The real cost savings can be in maintenance - as that's what will cost way more over the life of the elevator than the elevator itself.
So, when designing a relay circuit for an elevator, it shouldn't be merely about using the elevator as a model of behavior. There are also application-specific aspects, and maintainability, ease of diagnostics and part availability make a big difference. Perhaps it's not something of big importance in an introductory controls course, but such topics don't exist in vacuum. Ultimately, these control systems end up applied in the real world. And there, the micro-optimizations such as relay counts alone are ill-considered without taking the bigger picture into account. Of significance are uniformity across different variants of the product, minimization of the number of different parts - to simplify stocking and procurement, the ease of training the maintenance personnel, and so on. That's what the user of any piece of equipment cares about a lot. $1000 in relays either way makes no big difference in that picture.
Now - don't get me wrong, gratuitously adding components may well decrease reliability. So everything has to be looked at in context. Sometimes less relays is more, sometimes more relays is less :)
