Generally asking, but primarily for KiCad, what is the schematic symbol typically used for FPC/FFC/flex cables?
That is to say, the flat end which is sometimes stiffened and does not have a connector like in the following image:
FFC
In KiCad, would the above cable be represented by Connector_Generic > Conn_01x14?
KiCad Connector_Generic > Conn_01x14
Or is this something that a Bus in KiCad can be used for? I doubt this because this appears to only be a way to make connections within a project, while in the use-case I'm asking about there is no further connection after this FFC (in the context of the project).
That is essentially the same as an edge connector on a normal PC board, so I'd use a generic connector as the schematic symbol.
