I have been looking around at different front end implementations for a DIY oscilloscope and came across a variant that I found simple enough as a starting point.
I have a question about protecting the inputs though. Please look at the attached schematic.
The way I understand it, there is no protection for the input of the OPA659 buffer. As per the datasheet, the maximum input can be 0.4V above 5V. Would this not mean that a higher signal mistakenly connected to the oscilloscope could damage it?
Would it make sense to clamp the input voltages to the +5V and -5V rails using clamping diodes?
Could I use a +-15V supply to increase the range of my input signals and modify the subsequent attenuation to bring it within range of my ADC?
