I have an LED driver circuit that is not behaving the way I expect it to. More precisely, it’s not drawing as much current as I expect it to do. The design is not originally mine, so I don’t know the motivation behind all design choices, but I suspect the design was mostly copied from the evaluation board for the LED driver that is used in the design. The schematic of the circuit is included below. It uses an NCL30160 LED driver to drive 4 different LEDs with wavelengths of 365, 400, 480 and 520 nm. The selection between the different LEDs is done with a BTS5200-4EKA high side switch, and the intensity of the LEDs is controlled by PWM (PC_PWM in the schematic) enter image description here
The LEDs are from a company called Lumixtar with the following part numbers:
WL-5P5050EP120UV-365
WL-5P5050EP120UV-400
WL-5P5050EP120B-480
WL-5P5050EP120G-520
The 365, 400 and 480 nm LEDs have a listed forward voltage of 3.4V, while the 520 nm one has a listed forward voltage of 5.5V. All LEDs can handle a current of 700 mA. The design choices made for the NCL30160 LED driver are the current sense resistor that controls the current (R12 in the schematic), the large inductor (L2), off-time setting resistor (R14), catch diode (D3) and input capacitor (C2). The design seems to work fine, except for the issue that I’m not getting the current consumption that I thought I would. The selection of current sense resistor has been made to 0.27 Ohm, which according to the datasheet for the NCL30160 should result in an output current of 200 mV / 0.27 Ohm = 0.74A. However, I’m only getting a maximum of 233 mA of current. I’ve measured the current draw from a PSU at different PWM duty cycles and for the different LEDs and put it in the table below:
So I pulled out the oscilloscope to take a look at what’s going on. Below you can see in yellow the voltage of the LED- net label, between the inductor and the LEDs in the schematic above, and in blue the current measurement from the PSU, measured with a 100mV/A current clamp. These measurements are with 30%, 60% and 90% PWM duty cycles. I’m not entirely sure what’s going on, since I haven’t worked with LED drivers before, but from looking at that image and reading the datasheet I would guess that it does sort of what it’s supposed to do? The current ramps up until it hits a threshold, at which the FET starts rapidly switching on and off, depending on the tON and tOFF of the driver.
Figure 1 LED- voltage & overall current consumption, 30% duty cycle
Figure 2 LED- voltage & overall current consumption, 60% duty cycle
Figure 3 LED- voltage & overall current consumption, 90% duty cycle
My first theory was that the inductor selection was off, that with a larger inductor there would be less ripple and a higher average current, so I dug into the calculations for the inductor selection, which comes from the calculations for the tON and tOFF.
But these equations, nor the rest of the datasheet, doesn't give much recommendations on inductor sizing, beyond this bit of text:
After not being able to apply the equations properly I did what most engineers would probably have done, I simply swapped the inductor for something different to see what happened. I swapped the 100µH, 300mΩ inductor for a 15µH, 100mΩ one I had lying around, and then measured the current consumption again, with the results below.
Figure 4 LED- voltage & overall current consumption, 30% duty cycle, L = 15 uH
Figure 5 LED- voltage & overall current consumption, 60% duty cycle, L = 15 uH
Figure 6 LED- voltage & overall current consumption, 90% duty cycle, L = 15 uH
There’s some strange hysteresis effect going on between 90-100%. When I increase the duty cycle up from 90 -> 100% there’s a jump in current consumption and radical change in the switching frequency somewhere around 94-96%. Going back down it doesn’t “reset” until somewhere 92-94%.
The overall change in current consumption was negative, which I guess makes sense? The voltage regulation swings a lot more, which results in less overall current going through the LEDs. So, ignoring the consumption results ata 100% PWM the theory about larger inductor holds? So I then tried swapping the 100 µH inductor out for 2x 100µH inductors in series (I didn’t have any single SMD inductor at hand with a value larger than 100 µH, and stacking large components on PCBs is fun!) This didn’t have any impact on the current consumption at all pretty much unfortunately, the results were pretty much identical to the first table in this post.
Figure 7 Stacked inductors in series
Figure 8 LED- voltage & overall current consumption, 90% duty cycle, L = 200 uH
I then tested the swap the last component I could imagine would affect the current consumption, the off-time setting resistor. I didn’t expect this to have a large effect on the current consumption since the datasheet specifically states “The off-time setting resistor (ROT) programs the NCL30160 with the initial time duration that the MOSFET is turned off when the switching operation begins”, which I interpreted as that it shouldn’t have an effect on the continual switching, only the initial switch cycle. I changed it from 240k to 120k, and measured current consumption again, with the results below.
Figure 9 LED- voltage & overall current consumption, 30% duty cycle, L = 100 uH, Rot = 120k
This also didn’t change the overall current consumption, nor the shape of the wave forms, which I didn’t really expect it to.
So it’s at this point that I figured that I don’t really understand what’s going on here, and how the LED driver operates. I’m expecting the output current to be 0.74A continuously, based on the datasheet, but maybe that’s not the correct assumption? Maybe the LED driver is working exactly as it’s supposed to?
  • \$\begingroup\$ Have you tried measuring the voltage across your sense resistor? Or from CS pin to ground? \$\endgroup\$ May 5 at 14:55
I'm not sure where you're getting your numbers from (this is why you should link the datasheets you are using). I see typical Vf of the 480nm and 400nm LEDs as about 6.5V (6 to 7V). I only looked at those ones. They have two LEDs in series and two parallel strings.
So power consumption at 700mA would be around 4.5W. At 85% efficiency (Fig 10, two LEDs) the total consumption @24V would be around 220mA, plus a bit for the losses in the high-side switch and consumption of the chips themselves. That's pretty much what you are seeing. If I am interpreting your numbers correctly, the circuit is behaving as expected.
  • \$\begingroup\$ Yes, LED current is not the same as supply current, this circuit just works. \$\endgroup\$
    – Jens
    May 5 at 15:58
    \$\begingroup\$ Ah of course! I had understood it as that the constant-current mode of the LED driver would pull the listed current from the 24V VCC line, but that's where my misunderstanding lies. Thank you for the explanation! \$\endgroup\$ May 8 at 8:39
