10
My code:
module adder(a,b,result);
   input wire [9:0] a,b;
   output wire [10:0] result;
   assign result = a + b;
endmodule
My company recently changed policy to escalate the linting rule (W164a and W164b) mismatch of LHS and RHS bit widths from warnings to errors. Now I either have to waive these lines of code to tell the linting software not to freak out, or I have to prepend 1'b0 to both a & b.
What is the right approach here?
13
The right approach is to discuss this situation with the people in your company who recently changed the policy. Your Verilog code is very clean, and it is a common way to add numbers together. Prepending 1'b0 to both a & b will result in code that is not commonly seen.
If you can not convince them to change this back to a warning, then you should waive these lines of code.
    \$\begingroup\$ The reason stated for changing this was a lesson learnt in a previous project where they found some issue because they ignored this warning. I didn't discuss exactly what yet, but will do it. Thanks for the reply! \$\endgroup\$ May 5, 2023 at 19:59
    \$\begingroup\$ @nebuchadnezzar_II found some issue because they ignored this warning is unexpected. \$\endgroup\$
    – greybeard
    May 6, 2023 at 5:13
    \$\begingroup\$ The obvious error case is where a or b is a signed quantity with a negative value and the variable is not marked signed. \$\endgroup\$
    – grahamj42
    May 7, 2023 at 7:12
  • \$\begingroup\$ @greybeard, I agree and I'm not able to imagine such a situation. As grahamj42 points out, we do have the datapath switching in certain modes to signed representation. \$\endgroup\$ May 8, 2023 at 19:27
8
IMHO, padding 0's should not be an error. Only implicit casting with the potential loss of data should be a warning or error. Consider using SystemVerilog's explicit casting in place of waivers
assign result = 11'(a + b);
