I'm using an HTRC C150 charger to charge a single-cell LiPo battery for my RC quadcopter.
When I let the device charge the battery, it ends with a reading of 4.2V, however, when I connect a multimeter to my battery it reads 4.05V instead.
While the battery was charging, I took a reading at the output terminals of the device which read around 4.1V. I have two three questions about this:
- Is the voltage difference because the cables/device aren't perfect conductors (i.e. they have some resistance), and therefore dissipate some of the DC current's energy over the distance of the wires?
- Is this normal for a charger to be off that much? Or did I just get something cheap, and would investing in a higher quality charger fix this?
- Is it possible to calibrate the charger somehow to offset for this voltage difference?
Edit: This is the second HTRC charger I've tried, since the first one had a similar issue and I returned it thinking it was the charger, but now I'm questioning my small understanding of electrical engineering haha. Also, to be clear, the 4.05V reading was when the battery was disconnected, and the 4.1V reading was made by pulling out the black/red plugs from the device a little bit and contacting the multimeter to those in parallel to the charging. I also made another reading (that I haven't mentioned yet) on the battery itself while it was charging by pressing the terminals against the exposed metal bits on the JST cables, and that read 4.06V (which makes sense to me why it'd be slightly higher; the charger is sending a slight current into it). I am fairly confident that my multimeter is working correctly, since it reads other batteries of known voltages correctly (like 9V or AA batteries).
