I've done a bit of experimenting with Verilog recently, and I ran into a problem where it doesn't behave as I'd expect. In one of my modules, I have code like the following that is designed to simply track odd/even cycles, because I'm performing operations that take 2 cycles each:
reg even_cycle = 0;
always@(posedge clk)
begin
    even_cycle <= ~even_cycle;
    if(even_cycle)
        //do something
end
The expected behaviour: On the first clock cycle, even_cycle is flipped, which, due to it being a register should see it continue to show zero until the next cycle, where its new value of 1 will be clocked.
What really happens: On the positive edge of the first clock cycle, even_cycle is already set to 1
I'm sure I'm missing something obvious, but could anyone please explain this behaviour? It seems to go against my understanding of registers. How can a reg's value appear to be updated on the same cycle it's assigned?
As a bonus question, if I have a clock signal that I want to pass to a module conditionally, is the following a bad way of doing it? If so, is there a recommended way?
input clk_in; //always running
wire cond_clk;
assign cond_clk = some_condition ? clk_in : 0
When run in the simulator and I stop the clock (i.e the condition becomes false), cond_clk shows as a vertical line in the simulator, as if it's high for a tiny period at the beginning of the cycle.
  • \$\begingroup\$ Which line is doing something you didn't expect? The even_cycle <= ~even_cycle or the if(even_cycle) ? \$\endgroup\$
    – Ben Voigt
    May 9, 2023 at 21:37
  • \$\begingroup\$ For your bonus question, FPGA logic blocks are designed with "clock enable" signals, e.g. if (some_condition && posedge clk). Clock gating risks glitching, unless you use the clock gating features associated with global clock trees. Which is not a bad tradeoff -- the advantage of clock gating over clock enable is power-saving, and for that to be worthwhile, it has to affect a large amount of circuitry (hence global clock tree) \$\endgroup\$
    – Ben Voigt
    May 9, 2023 at 21:42
  • \$\begingroup\$ @BenVoigt Thank you, I will do some reading on that subject \$\endgroup\$
    – Triforcer
    May 9, 2023 at 22:15
The simulation behaves as it should. At the positive edge of clk, the nonblocking assignment is executed, updating the even_cycle signal with its new value, which is always the inverse of its previous value.
At time 0, you set even_cycle to 0 in the reg declaration line. It stays at 0 until the 1st positive edge of clk. At that time, even_cycle becomes 1.
Consider this simple code:
module tb;
reg clk = 0;
always #5 clk++;
reg even_cycle = 0;
always @(posedge clk)
begin
end
initial #500 $finish;
endmodule
Assuming clk is 0 at time 0 and goes to 1 at time 5, even_cycle goes high at time 5 as well. It then remains at 1 until the 2nd positive edge of clk at time 15. This code models a positive-edge triggered flip flop.
  • \$\begingroup\$ Thanks, I think that confused me because it almost seems like the register behaves differently on the first cycle than on subsequent ones. Considering this normal behaviour, how might I ensure that even_cycle remains at zero for the first clock cycle as I was incorrectly anticipating it would? Do I have to use some additional logic to handle it? \$\endgroup\$
    – Triforcer
    May 9, 2023 at 22:07
  • \$\begingroup\$ @Triforcer toggle on falling edge of the clock \$\endgroup\$
    – jsotola
    May 10, 2023 at 0:51
  • \$\begingroup\$ Also: any process that is synchronous to a clock will see the old value of any signal that changes with the same rising edge. So if you output even_cycle to the console, the first value you should see in the log is 0, and any other logic that is synchronous to clk would also register even_cycle as 0 with the first rising edge. \$\endgroup\$ May 11, 2023 at 6:08
