I'm not sure how to go about this, but the answers are below
1 Answer
Here's a hint that simplifies your circuit in order to find the current through the 20 Ω resistor: -
- Do you understand the source transformation that I made?
- Do you know how to calculate the net value of parallel resistors?
- Can you then solve for \$I_{20}\$?
Of course you could solve it with superposition but it's easier this way IMHO.
- Once you have \$I_{20}\$ you can then reapply that current to your original circuit
- And calculate the voltage at the common node of the three resistors That then gives you \$I_{40}\$ quite automatically
- Once you have \$I_{20}\$ and \$I_{40}\$, and \$I_{10}\$ is easily revealed
\$\begingroup\$ It was actually quite easy, I'm not an EE but for some reason, it's on my uni course, thanks for any help provided. I realised I was overthinking a bit... \$\endgroup\$– XeocasCommented May 13, 2023 at 20:52
What is your question? \$\endgroup\$
