I am trying to write a code that converts binary to thermometer code. Thermometer (a.k.a. unary) coding is frequently used in digital systems applications to represent a natural number.
In a thermometer code, an N-bit binary number is represented by a (2 ** N)-bit digital word, which has m zeros followed by (N - m) ones or vice-versa. Basically, if you have a 4-bit binary number say 0110 (decimal is 6), the equivalent thermometer code will be of width 2^4 (=16), and its value will be 6 ones following 10 zeroes (0000000000111111).
module model (
input [7:0] din,
output reg [255:0] dout
logic [255:0] tempout;
int count;
always @ (*) begin
count <= din;
tempout<= '0;
end
generate
for (genvar i=0; i <= count; i++) begin
tempout[i] = 1;
end
endgenerate
assign dout = tempout;
endmodule
I am getting the following error for this code:
%Error: Loop unrolling failed.
%Error-UNSUPPORTED: Unsupported: Can't unroll generate for; Unable to unroll loop
For error description see https://verilator.org/warn/UNSUPPORTED?v=4.228
What is wrong with my code?
I have a working code also, but it goes through the loop 2^N number of times, and I want to reduce that.
localparam LP_DATA_SIZE = 8;
generate
for (genvar i = 0; i < 2**LP_DATA_SIZE; i++) begin
assign dout[i] = (i <= din);
end
endgenerate
for
loop must be known at compile time; it can't be controlled by an input port. \$\endgroup\$
