What is the name of this connector?
It´s about 4mm x 8.5mm x 6.5mm
Picture 1
Picture 2
This is the counterpart:
Picture 3
  • \$\begingroup\$ Please provide pitch and other dimensions. \$\endgroup\$
    – Voltage Spike
    Commented May 15, 2023 at 16:17
  • \$\begingroup\$ It looks like a JST, but that's a brand, not a specific connector. As voltage spike says, dimensions are needed. \$\endgroup\$
    – LordTeddy
    Commented May 15, 2023 at 16:27
  • \$\begingroup\$ I edited the post \$\endgroup\$ Commented May 15, 2023 at 17:06
  • \$\begingroup\$ pitch means the distance between the pins, and is pretty important. Measure the distance between all of them and divide by 3, for this particular connector \$\endgroup\$
    – LordTeddy
    Commented May 15, 2023 at 17:31
  • \$\begingroup\$ It´s about 2mm. \$\endgroup\$ Commented May 15, 2023 at 18:23
It is a JST PH type connector (not necessarily JST brand) with 4 pins.
Here is the JST datasheet, which gives part numbers for various members of the PH family.
Here is an image of PH family parts that I obtained from here
  • \$\begingroup\$ Links are not working, but i still got the needed information. thank you! \$\endgroup\$ Commented May 16, 2023 at 8:14
  • \$\begingroup\$ @NurDerFch1846 JST is a well-known connector manufacturer. JST PH family. \$\endgroup\$
    – Lundin
    Commented May 16, 2023 at 14:22
