I simulated a LC-converter with a verly low static switching frequency of 300 Hz. I expected the current in C1 and L2 in a sinosoidal shape but instead it is almost a square wave. Also there is a oscillation on the voltage Vnode of 75 kHz.
In the FFT of I(C1) it can be seen that the fundamental frequency is at the resonant frequency of C1/L2 of 300 Hz.
Like in LC or LLC converters I expected a sinosoidal current shape. Is my expectation wrong or did I do something wrong with the simulation?
LTspice Netlist:
C1 N002 Vnode 1.41m
D2 N003 Vout+ 1SR154-600
D4 N001 Vout+ 1SR154-600
C2 Vout+ 0 3000µ
R1 Vout+ 0 200
L2 N002 0 0.2m
L3 0 N003 0.1m
L4 N001 0 0.1m
V3 Vsource 0 100
V4 Vg_HS Vnode PWL REPEAT FOREVER (0 5 0.00157 5 0.0016 0 0.00327 0 0.0033 5) ENDREPEAT
V5 Vg_LS 0 PWL REPEAT FOREVER (0 0 0.00163 0 0.00165 5 0.003247 5 0.00325 0 0.0033 0) ENDREPEAT
M1 Vsource Vg_HS Vnode Vnode IRFH5020
M2 Vnode Vg_LS 0 0 IRFH5020
.model D D
.lib C:\Users\hamsn\Documents\LTspiceXVII\lib\cmp\standard.dio
.model NMOS NMOS
.model PMOS PMOS
.lib C:\Users\hamsn\Documents\LTspiceXVII\lib\cmp\standard.mos
.tran 75m startup uic
K1 L2 L3 L4 1
.backanno
.end
