I'm trying to calculate the RMS current of a flyback converters primary switch node. The Waveform is shown below:
I'm okay with assuming it is a triangle wave with a duty cycle of 50%. The peak value is 1.25A and the Period time is 4u seconds.
I can calculate it using the following formula I found on the internet:
Text
And I will find a RMS current of 0.51A what is right.
But my problem is when I try to calculate it with another method i believe is right I get a different answer. I hope someone can point out me where I'm wrong. See my calculation below:
$$ I_{RMS} = \sqrt{\frac{1}{T}\cdot\int_{0}^{T}I^2(t)dt} $$
I then simplify the integral to an easy area calculation
$$\int_{0}^{T}I^2(t)dt = (0.5 \cdot 0.5T \cdot I_{PK})^2$$
I work this all out to the following:
$$I_{RMS} = \sqrt{\frac{1}{T}(0.5 \cdot 0.5T \cdot I_{PK})^2}$$
When i fill everything in:
$$I_{RMS} = \sqrt{\frac{1}{4\mu}(0.5 \cdot 0.5 \cdot 2\mu \cdot 1.25)^2} $$ $$I_{RMS} = 3.125\cdot10^{-4} A $$
I end up wrong. I think my problem is with the simplification. But it doesn't make sense to me why it should be wrong.
Apply dimensional analysis to see your error. In the third step, you have:
$$ (A) \equiv \sqrt{(s^{-1}) \left[ (A) (s) \right]^2} = \sqrt{ A^2 s} = A \sqrt{ s} $$
which fails the equivalence on the left.
The curve you need to integrate is a quadratic, from 0 to DT, and the remainder (from DT to T) is zero. The antiderivative of the square is 1/3 of the cube, which lies is under the radical, hence where the \$\sqrt{3}\$ fraction comes from.
  • \$\begingroup\$ Thanks for this anwser. I see now where my problem lies. And found my error when simplifying. \$\endgroup\$ May 16, 2023 at 8:25
