I have the following circuit (see picture 1) where the switch \$ 0 - 1 - 2 \$ is in the "state" \$ 0 - 2\$. The values are \$ R_1 = 20~\Omega \$ , \$ R_2 = 30~\Omega \$, \$ R_3 = 10~\Omega \$, \$ I_q = 4~\mathrm{A} \$, and \$ L = 80~\mathrm{mH} \$.
I have to find the equivalent voltage source to determine the first order ODE for the inductor current \$ i_L(t) \$. This was the note from the professor.
So I tried to do this like in picture 2.
I replaced the current source \$ I_q \$ and the parallel resistor \$ R_2 \$ (both in picture 1) with the voltage source \$ U_q \$ and the series resistor \$ R_2 \$. I know that \$ U_q = I_q \cdot R_2 \$.
But there is an example in the script of the professor where the inductor \$ L \$ is removed and replaced with two clamps (see picture 3).
As an intermediate step to determine the ODE I have to calculate the voltage between the clamps \$ U_{kl} \$ and the internal resistance \$ R_i \$.
I tried to calculate the internal resistance \$ R_i = R_2 + R_3 = 30~\Omega + 10~\Omega = 40~\Omega \$ (see picture 4). This seems to be accurate because the solution, which was given from the professor is \$ 40~\Omega \$. But I'm not sure how to calculate \$ U_{kl} \$ and if I even did the transformation to the equivalent voltage source correctly, because the solution for \$ U_{kl} \$ is \$ 120~\mathrm{V} \$ but I got this for \$ U_q \$.
Can it be that \$ U_q = U_{kl} \$ ?
