I'm currently trying to figure out how to design a free running ramp generator for a project. I'm required to use op amps for both the bootstrap sawtooth generator and the Schmitt trigger, and the required output voltage ranges from -8 to -1 V. This implies that the UTP is -1 and the LTP is -8.
I'm having a hard time understanding how the output of the bootstrap would be negative along with designing the Schmitt trigger such that both threshold voltages are also negative. Any tips? I've attached a picture of the reference circuit that they've provided, which is the only reference material provided to us.
    \$\begingroup\$ Have you considered using a simulator and seeing how the circuit in your question performs? \$\endgroup\$
    May 18, 2023 at 9:06
Here is what the behavior should be, beginning with voltages across C1 and C2.
NB: opamp's are LF13741.
Zooming in some regions ...
Starting "block" ...
And repeating "block" ...
And here the "ideal DC cyclogram" for the hysteresis part.
And here is the "transient cyclogram" of the hysteresis part.
