I want to measure the arrival time of three seperate digital pulses with respect to a global trigger.
The longest arrival time is expected to be <10ms and it would need to be able to determine the arrival time to <1us
The jitter of the timing is more important than latency, as I will be comparing the three arrival times. Therefore any systematic errors can be ignored.
This will a part of a control system running at about 100Hz on a microcontroller.
What is the simplest solution in this case?
  • \$\begingroup\$ I would use a 4-Channel Scope with the required time-resolution. \$\endgroup\$ May 18, 2023 at 18:27
  • \$\begingroup\$ This is a great example of why we have oscilloscopes. \$\endgroup\$ May 18, 2023 at 18:32
  • \$\begingroup\$ Sorry I wasn't clear enough on the context. This will be running at about 100Hz and form a control system circuit \$\endgroup\$
    – Flemingjp
    May 18, 2023 at 19:01
  • \$\begingroup\$ A micro with several timer-counters. \$\endgroup\$
    – RussellH
    May 18, 2023 at 19:05
  • \$\begingroup\$ Is it common for microcontrollers to habe several timer-counters? Can they achieve sub-microsecond resolution? Any microcontroller suggestions? \$\endgroup\$
    – Flemingjp
    May 18, 2023 at 19:12
Use a MCU with 16-bit timer that has 3 input capture channels.
At least 1 us resolution means timer must run at least at 1 MHz. To measure up to 10ms, that's 10000 us. So a timer with 16 bits could measure up to 65ms, or you can run it faster like at 5-6 MHz to measure up to 13.1 or 10.9 ms to get more resolution.
