Typically, when analysis the stability of a single loop circuit, we can use the open-loop method, just to break the loop and get the loop gain. Then, using the Bode diagram, we can easily get the PM(Phase Margin) information, from that we can predict how the transient response will look like.
However, when analysis the stability of a multi-loop circuit, if we also use the open-loop method, we will get two different loop gain from different break point.
Theoretically, we can still get the same absolute stability information from both two loop gain, but the two loop gain show the different information about PM.
So, my question is -- How could we predict the transient response of the multi-loop circuit?
For example, if one of the loop gain is 90°, and the another loop gain is 45°, will the circuit’s transient response look like overdamped or underdamped?
Hope to get an answer, thanks.
