Q1 is an IC. I just used that symbol as a placeholder. So all this chip does is gradually brighten and dim each of the LED lines, in overlapping intervals. So red brightens, then as red dims, green brightens, then as green dims, blue brightens, and so on. The IC receives a constant 12 V. There is no part number on the IC and I've replicated the board perfectly in the schematic.
Edit: theres another resistor from pin 1 to pin 4.
